メインコンテンツにスキップ
モデル番号はA1625。A8プロセッサと2GBのRAMを搭載したAppleのセットトップボックスの2015年改訂モデルです。
30回答 すべてを表示
How to power Apple TV 4 in the car? 12v adapter?
Is there a 12v power supply solution for the Apple TV 4? I want to be able to run the apple tv from the 12v ignition supply from the car battery so that i can run videos to the car screen.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント
How do you expect to stream from iTunes?
さんによる
I don't need iTunes, my car has a built in wifi hotspot and I can tether from my phone or iPad for Internet. The new Apple TV has apps so it's more than just an iTunes Player
さんによる
From my understanding AppleTV apps are still tethered to iTunes for them to run. So you'll still need access to the internet as you are driving.
さんによる
Yes as I have said I have wifi hotspot built in... Now how about you try and answer the actual question Dan ?
さんによる
コメントを追加
5件の回答
ベストアンサー
You'll need a car DC to AC converter like this one: Tripp Lite PV150 Ultra 150 Watt Power Inverter so you can plug in the AC cord of the AppleTV into. We use these for our field staff to use their laptops in the field.
There is no 12volt power supply option for the AppleTV it was never designed to be a mobile device.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yes I already have one of those adapters but I want something more neater hence asking for a 12v solution. I know someone has done it on the apple tv3 but wondering if a newer one has been released
さんによる
コメントを追加
http://carsystems.com.ua/universal-solut...
I just ordered this to install an Apple TV 4 in my camper. Did not receive it yet.
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
Did you receive it yet?
さんによる
Yes, I received it. It took quite a long time to travel, although it was posted next day. This seems to be due to customs. Nevertheless it arrived and is a really good solution. Even the 220V connector is replaced for a standard low voltage connector. It works like it should :-)
さんによる
I philippemeyers did you order it from the Ukraine as I've sent them a skype to find out where i can get one
さんによる
Did you hear back? Where did you order from?
さんによる
I ordered one from http://carsystems.com.ua/universal-solut...
works perfect and the service was very good
さんによる
4件以上のコメントを表示
コメントを追加
Here is a US seller of the Apple TV4 PS: http://www.ebay.com/itm/122333123212
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Here is another:
http://mct-corp.com/store/index.php?prod...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Is the way to do it without spending a nickel
https://m.youtube.com/watch?v=cao5UahhN6...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Deleted193439577 さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 33
過去 30 日: 159
今までの合計 34,854
