メインコンテンツにスキップ
Rechargeable indoor/outdoor Bluetooth speaker. Capable of using USB, AUX and SD card for music input. Product released in 2014.
Why does my speaker lose battery so fast?
I made sure to fully charge my speaker before bringing it outside. The LED light indicated that it was fully charged. 30 minutes into listening, my speaker died.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
I have that problem also. I changed the wires the Speaker everything
さんによる
コメントを追加
1 件の回答
ベストアンサー
If you are unsure if your battery was fully charged you can plug it in. If the battery does not have a full charge a red LED light will appear. Once this light turns off the battery is at maximum capacity.
If you are sure that your battery was at full charge when you began using it and the battery life was not satisfactory, then you may want to consider replacing your battery to extend the devices longevity. To learn how to replace your battery please see the the troubleshooting guide here: Troubleshooting Page
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Elvira Lou Evangelista さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 16
今までの合計 16,820
