Why is there buzzing in my audio jack?
I accidentally dropped my phone into the toilet and now when I put my headphones in I keep getting a lot of static. What should I do to about this??
Your problem is twofold either your motherboard has been corroded or the your audio jack has rusted on the inside. You can do one of two things. You can either solder on a new audio jack which might take a little work, but if you like tinkering this is a fun project. Secondly, you can replace the motherboard with a new one, and it will work good as new.
このアンサーは役に立ちましたか?
look at this link. it may help
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 103
