メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
Recover data after water damage, does not boot up
iPhone 6 Plus -will not power on after water damage. Steps tried. Drying display connectors both from display and at logic board. connected to power via USB lightning charger and it will not power on. Is there a way to pull data of of this device with out using itunes and for free?
-Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
No, you will need to find a way to power up the device and connect it to iTunes or iCloud. It is not possible to decrypt the files without the key derived from the CPU UID and your passcode, so extracting the files from a dead board is not possible whatsoever.
And I predict there will be spammers promoting "data recovery" tools that are useless.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
As Sunday mentioned in the comments below, your best bet is to send it to someone who does board level repair.
I would stop trying to connect it to power, as that will only make things worse.
There is definitely no free way of going about it. It's going to cost you money, so unless the data is worth a lot to you its probably not worth bothering.
If the data is valuable to you, you can find someone at http://boardrepair.info (including iPadRehab as Sunday mentioned) to mail the device to for data recovery.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Nate A さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 256
