メインコンテンツにスキップ
Mid 2010 Model A1278 / 2.4 もしくは 2.66 GHz Core 2 Duoプロセッサ
794回答 すべてを表示
Is this the correct diagnosis for hard drive not being read?
As follows is my diagnosis process. I believe my hard drive ribbon cable has failed but I would appreciate confirmation.
  1. Booted laptop and got the question mark folder symbol.
  2. Tested drive by copying off its contents onto another computer. Drive was healthy.
  3. With the old hard drive connected externally through an enclosure, I booted the laptop off of a USB connection, with no drive inside. This restored full functionality, but is not a desirable solution. Thus, the logic board should be healthy as well.
Is the ribbon cable the only thing that could be broken here, or is it possible that the headers on the logic board are broken/something similar? I still see the front on/off light turn on and off correctly, so one would hope the headers are fine, but I would appreciate any input on other routes of failure.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Hi John,
Good diagnosis process. Yes, it does sound like the hard drive cable is the likely culprit. Macbook Pros can be notorious (especially later models) for having HDD cable issues. Having the board connectors fail is much, much less common, and the only way to confirm that is to use known good cables and drives.
Here's the cable you're looking for. Double check it's the right one for your model machine.
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Hard Drive Cable
Happy repairing,
Andrew
MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Hard Drive Cableの画像
製品
$34.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
John S さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 62
