Why is my GPS not responding to my voice commands?
When i say a command my GPS is unresponsive, no matter how loud I command it to do something I still get the same results. What should i do to fix this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The microphone is no longer attached to the motherboard and that is most likely the problem. Follow the provided link for more help!
このアンサーは役に立ちましたか?
I had that problem also and it drove me nuts but I figured it out and it was so simple it was stupid. After I updated the maps and made sure regions and language matched and everything set to english. Now do this.on your post screen hit the APPs button scroll down to voice command. Now hit the little tool icon at the top left and uncheck Voice Command wait a few seconds then CHECK voice Command turning it back on. then it started working again.
my nuvi dosnt even have a voice command app so now what?cant even get off the ground with my new nuvi 68
There are so many reasons that GPS not responding to my voice commands?
Below are some of them:
To solve this Voice Command Not Working in GPS, you can perform a hard reset of your device, make sure you store all the backup of your device.
If problem not solved then feel free to contact Service Center.
このアンサーは役に立ちましたか?
Some popular Gps devices like- Magellan devices like magellan maestro 3200,magellan roadmate 1440,magellan maestro 4040, magellan roadmate 5235t-lm,magellan roadmate 1700,magellan roadmate 1470, and other old and newer models. We’ll help you to get easy maps, software / Firmware updates.
Are you planning a trip or going out and wondering if you could have the latest maps to make your trip or your work. Well, you’re a step away from the latest map updates. Latest map updates make sure that you always reach your destination on time with full-proof accuracy. Magellan roadmate Updates
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 25
今までの合計 8,876
