Logicboard transplant! Is it Possible?
Will the logicboard from a G4 1.42 work inside a G4 1.33 machine? Help appreciated
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sorry but no. The 1.42 has different connectors on the logic board so you wont be able to connect your 1.33 airport card, hard drive, trackpad, inverter cable and the reed switch module is also different. Try to find a good working 1.33 logic board instead.
このアンサーは役に立ちましたか?
Thanks for the info! Saves a lot of hassle, appreciate the help.
過去 24時間: 1
過去 7 日: 3
過去 30 日: 7
今までの合計 823
