メインコンテンツにスキップ
対象のモデルはA1419 / EMC 2806 / Late 2014 または Mid 2015。 3.3 または 3.5GHz Core i5 または 4.0GHz Core i7 (機種ID iMac15,1)、EMC 2834 late 2015 / 3.3 または 3.5 GHz Core i5 または 4.0 GHz Core i7 (機種ID iMac17,1)のRetina 5Kディスプレイを搭載したすべて。
573回答 すべてを表示
scratch on the screen
Yesterday in the course of replacing the hard drive, I hurt the black paint (black box) on the inner side of the screen when cutting. Does anyone know how to repair it? Some paint? Scratches are at the bottom of the screen.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Sadly there is no means to touchup the paint as you cut into the seam between the cover glass (which is painted) and the LCD panel.
Apple fuses the two together so dust or dirt does not collect between the glass plates. You would need to finish cutting around the cover glass clean it off and then repaint it. The rub here is you'll end up making a much bigger mess and you'll more than likely break cover glass or damage the LCD which would mean you'd end up replacing the complete assembly which would be quite expensive!
Bottom line here: Leave it alone! As you'll end up making a more expensive repair out of this!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
John さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 1,486
