メインコンテンツにスキップ
The Dremel 4000 is a variable speed rotary device. It is compatible with with all Dremel rotary accessories.
17回答 すべてを表示
締切られた回答
How do I separate the housing set after removing the screws?
I removed the screws but the housing set is stuck on the ergonomic grip. I tried prying it open with a plastic tool, but it started to damage the external case. Where should I pry open the Dremel 4000 to avoid this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The Dremel 4000's cushioned grip which can make it a challenge to pry apart the casing. The key is to first remove the housing cap which will expose the hard plastic threads of the exoskeleton, then use your prying tool to start a wedge there. This troubleshooting page may have additional useful information.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 3
今までの合計 446
