メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Likelihood of ultraonic cleaner + isopropanol fixing water damage?
If I have a water damaged iPhone 6 which isn't turning on due to water damage, what is the likelihood that putting it in an ultrasonic cleaner with 99.9% isopropanol will fix it?
Out of ten, roughly, how many would it fix?
And what's the recommended amount of time to leave it in the Ultra sonic cleaner for?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
Hi john to answer your question is the ultrasonic cleaner and I am talking the $100 versions for me it works 7 out of 10 times and I set mine on for about 5 to ten minutes but I use electronic cleaning solution and my mixture is about 4% cleaner and 96% distilled water but with the alcohol solution I am going to be honest and say I don't know. The stuff I use is industrial so you have to contact the company to get it but here is the link http://www.echemproducts.com/ultrasonic-... now for the ultrasonic cleaner this is what I use and your getting a better deal than I did for $76 instead of a $100 https://www.pce-instruments.com/us/index.... Here is the cleaning solution you can easily get your hands on http://www.all-spec.com/products/635-022...
このアンサーは役に立ちましたか?
スコア 5
7 件のコメント:
Please add a brand name and link to ultrasonic and cleaner solution.
さんによる
I will try to find a not so industrial cleaning solution to for you guys and I am truly grateful mayer that with that comment you helped me improve the way I answer questions.
さんによる
@meepfish1 Answering questions well is a learning process and you get better at it over time. You're doing fine ;-)
さんによる
Thanks @meepfish1 eepfish1! I have this Ultrasonic Cleaner - http://www.amazon.co.uk/Floureon-Ultraso...
Does it seem alright, do you think? And would you assume that 10 minutes is probably a good amount of time for the alcohol method?
Have you had any experience using alcohol?
さんによる
STOP - using alcohol in an ultrasonic would not be a good idea. Think of an open bowl of petrol or gasoline being vibrated and emitting fumes around an electrical ignition source. https://www.youtube.com/watch?v=iWtohHwN...
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
John Taylor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 5
今までの合計 289
