I cant get my Asus tablet out of boot loop. please help!
You probably need to either restore the software on the phone or do a factory reset.
Follow this guide here in order to attempt to bring the tablet back to working order:
このアンサーは役に立ちましたか?
It may sound silly but I deal frequently with Lenovo tablet \ PCs and quite often we have to remove the battery, let sit for a few mins then powering it on again before continuing.
Our Levonos would often appear to boot through the POST (Power On Self Test) process then restart the process again as opposed to proceeding to boot into the OS.
このアンサーは役に立ちましたか?
Just want to mention for anyone else struggling with this issue, what fixed it for me:
I found the reboot would only happen when wifi was turned on, and even more weird, it would only happen when connected to specific wifi networks. After doing a factory reset I was able to set it up again by tethering to the wifi on my phone. I then found that I actually was able to connect to the problematic wifi network but only by setting a static IP! This has completely resolved the issue for me.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 13
今までの合計 10,147
My asus laptop is in a boot loop how would i be able to sort it
Carl Ashton さんによる
