メインコンテンツにスキップ
Also known as the Moto G3—an Android smartphone released by Motorola in July 2015. It serves as an economical alternative to Motorola's flagship phones. Model XT1540 in the US, with dual-sim and "Turbo Edition" variants sold in other regions.
89回答 すべてを表示
Can I replace a charging port for the Moto G?
Hey everyone,
My phone doesn't want to charge no matter what I do to it, and I have tried a dozen different charging cords. I had someone change my battery for me, but that did not fix the problem.
I have read online that the charging port can break, so I think that may be what happened. It this something that can be fixed, or do I need a new phone?
Thanks,
James
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
6 件のコメント
@copelanite this is a relatively new phone. Have you considered that it might still be under warranty?
さんによる
Good thought. I bought the phone right when it came out, so I am not sure if the warranty is still good, but I can contact Motorola to find out. If not, I'll just try to replace the charging port.
さんによる
Let us know what you find out.
さんによる
Motorola's Limited Warranty for the Moto G covers your device for one year.
Warranty service for eligible repairs is available at no charge for twelve months from the date of original retail purchase ("date of purchase").
You damage would be covered and of course can you void this warranty and follow the guide that is yet to appear. Nice assignment
さんによる
Thank you for the information! This will be very helpful.
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
Hi James,
It is possible to replace the charging port for this phone, and by the sounds of it you may want to try that solution. When you plug the charger into the phone does it fit in securely or is it loose? If it is loose the charging port may have been damaged, causing your problem. If you take a look at the troubleshooting page, there appears to be a replacement guide in the works for the charging port. I would bookmark that page and check back often for any updates.
If the charger fits in securely and you are positive there is no issue with either battery you have tried, I would contact Motorola support regarding your issue.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
James Copeland さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 30
今までの合計 26,788
