メインコンテンツにスキップ
Released in January 2012, the LG Spectrum is a 4G LTE phone with an 8MP rear-facing camera and a 1.3MP front-facing camera. The LG Spectrum is the first in its product line and runs on Android 4.0 with 1280x720 screen resolution.
2回答 すべてを表示
締切られた回答
Why isn’t there any audio coming from the phone?
My LG Spectrum’s speakers do not give off any sound while I’m playing music, videos, or games, and does not make any sound when I receive any notifications. I have been having this for quite a while, and would like some help. Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
@aimansallam do you get any sounds when you use headphones?
さんによる
コメントを追加
1 件の回答
Before jumping to any conclusions about hardware, check to make sure that you have your volume turned up on the phone itself, or if it’s just one specific app, look into the settings on that app to see if there is a separate volume slider that you might have accidentally turned off. If neither of those were the issue, then you have either a damaged speaker inside the phone, or if you are using headphones, a damaged auxiliary port.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 94
