My headphone jack is very lose
hi
recently the headphone port on my macbook has become very lose and the headphones will easily come out.
my questions is there an easy way to fix this or is it remove and replace the jack
この質問は役に立ちましたか?
hi
この質問は役に立ちましたか?
Sadly this is not an easy fix :-(
The socket is mounted on the logic board and you'll need to fully remove it to even have a chance of replacing it. This is a job for someone with microsodering skills and the needed parts.
Frankly, I would look for a USB DAC unit as the cheaper way around this. Here's one example: AudioEngine D3
The last option here is to replace the logic board.
このアンサーは役に立ちましたか?
ok thanks
will keep using it until its unusable
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 69
