メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2010万画素のデジタルカメラ。静止画および動画の撮影に対応。モデル番号:DSC-W800。
Why will my device not power on?
Why won't my Sony Cyber-shot DSC-W800 power on? When pressing the power button nothing displays on the screen and the device seems to be unresponsive.
Could this be a battery issue or something more serious that would require repair?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
يرجى توضيح أكثر هذا قليلا
さんによる 共有
@tcampo what happens when you do replace the batteries? does it then turn on?
さんによる 共有
コメントを追加
1 件の回答
ベストアンサー
There may be several reasons why your device may not be powering on. Following are the common ones:
  • The battery may not be sufficiently charged. It may discharge automatically if not used over a long period of time. In this case, simply charge the battery. Also, check to make that the battery is inserted in correct orientation.
  • The battery terminal may not be clean. You may clean the terminal with microfiber.
  • External temperature also effects the way the camera functions. Thus, make sure to not use the camera when the temperature is above or below 0-40° C. Condensation might occur if the camera is moved from extremely cold temperature to a warm environment, which could prevent the camera from functioning properly. In that case, let it come to room temperature and allow the condensation to evaporate naturally.
  • For more information, refer to the troubleshooting page.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
Thomas Campo さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 23
今までの合計 2,046
