What error is 4MOt/4/40000003: HDD-1293
Can't find exact definition of the error code. Need help. Thanks in advance.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Your Hard Drive fan unit has failed!
Here's a good write up on how to read the error codes. While it's a bit dated it still works! How to invoke and interpret the Apple hardware tests
So if we dissect your error code: 4MO t/4/40000003: HDD-1293
The rest is not important here
このアンサーは役に立ちましたか?
Do we need to replace the HDD or we can replace only the fan to solve this issue??
You need a new fan as the fan motors tach has failed. How about creating your own question with your system details as this answer was just generic! If we know your exact model and your errors details we can guide you to the correct part & guide.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 7,453
