メインコンテンツにスキップ
A rotary tool by Wen with different speed settings and attachment options.
Why is my device not holding a bit?
I am trying to put a new bit in my rotary tool but it keeps falling off when I try to adjust it
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
The device collet nut, end piece, may be broken. It will need to be replaced.
You can check more information here.
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
最も参考になった回答
Rotary tools use different sized bits. Commonly a Tool like a Dremel uses a 1/4" collet size. A dental tool, such as the one I use, a Emesco jack rabbit uses 7/16" bits.
Make sure your bits are the correct size.
https://www.pinterest.com/pin/4602820243...
このアンサーは役に立ちましたか?
スコア 7
2 件のコメント:
mr.fixit were do you work to know how to fix every thing
さんによる
@rozema Cody. I work for myself. Tough employer! Makes me study everyday! Plus I'm old and been many things in my life. stock broker, options specialist, surgical tech, dental lab owner, jewelry store owner, computer programmer, Mac Repair Store owner, saint and sinner. pastor and general PITA to many. If I don't know the answer I go find it, I do the work and try to be the best I can be at what ever I attempt. Now I give it away to help others.
さんによる
コメントを追加
回答を追加する
Sergio Palacio さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 23
今までの合計 1,623
