メインコンテンツにスキップ
2.26 or 2.4 GHz / White plastic unibody enclosure
What is my Logic board reference number?
Following damage to my macbook (13-inch late 2009)
2.26GHz Intel Core 2 Duo
8GB 1067MHz DDR3
NVIDIA GeForce 9400M 256 MB
Serial number: W90054828PW
I have decided to replace the logic board with a 2nd hand one. However, there seem to be two reference numbers for the same model computer:
1) 820-2567-A 661-5395
2) 820-2883-A P7550
Will they both be compatible with my computer?
Is there likely to be much difference?
How do I find the reference number of my original?
Any comments gratefully received. Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
If you look on the edge of the logic board you should find the board ID number. If you stay with the 2.26 GHz board you should get the Rev2 board. You can find a used 2.26 GHz for about $70 US and the 2.4 GHz for $80 US.
2.26 GHz
Rev1
  • Logic Board ID - 820-2567-A
  • Apple P/N - 661-5589
Rev2 >> Current Board <<
  • Logic Board ID - 820-2883-A
2.4 GHz
  • Logic Board ID - 820-2877-A
  • Apple P/N - 661-5640
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hello,
please let me know - did the newer version worked? I have similar problem. But Im not sure if Rev 2 on the board will work - my SN: w8005er18pw, emc: 2350, board 820-2567-A (I searched and believe it is 661-5395). Please help me and send some more info to my email: pavel.doschko@gmail.com - Can I buy a rev 2 (661-5589) ? Is it fully compatible?
さんによる
コメントを追加
回答を追加する
Simon G さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 231
