メインコンテンツにスキップ
様々なブランドから製造されているラップトップPC(ノートブック)コンピューターの修理ガイド。
18858回答 すべてを表示
A lot of modern notebooks have no back access panel. Why?
Hi, a lot of modern notebooks have no simple back access panel to change hd or ram, do you know why? So, swapping a hard disk or upgrading a ram module requires to tear down the notebook to the mainboard—and, if still under warranty, this operation could invalidate it if something goes wrong while opening the laptop.
Do you know why hp, for example, builds laptops of this kind? Thanks for any reply to solve this mystery.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
@uzugiulio as you can imagine this will all only be speculation. Only the manufacturers will know the answer for sure. I could imagine that this is partially done so that people like you and I cannot service our hardware. Anytime something breaks you will have to go to an authorized service center. So it'll keep the end user away from doing repairs. Secondly, due to change in architecture i.e. soldered RAM (not replaceable) and SSD card instead of hard drives will ultimately require more of a teardown than a simple hatch to replace parts. For as long as consumers demand faster, smaller and more efficient hardware, this trend will most likely continue.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Giulio さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 418
