メインコンテンツにスキップ
The Wintec Filemate Clear is an Android tablet with a 7 inch screen and 1.2 GHz processor. The tablet features 2 cameras, 2 megapixel rear camera and a VGA front facing camera.
My tablet wont charge anymore already tried differt charger?
I have already tried different charger and pu different filemate tablet on my charger... Why won't my tablet charge?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
lunakrazyshedevil71 the other tablet you tried charged with your charger?
さんによる
Oldturkey03 yes the other tablet charged up withmy charger..the charger fits tight on other but is loose on mine.. Charger is not like most cell phone chargers... Can I use the USB port to charge?
さんによる
I don't think its the battery due to the way charger fits
さんによる
コメントを追加
1 件の回答
最も参考になった回答
lunakrazyshedevil71 if your charger work properly, then it is possible that you are having issues with either your battery or your charging port. Use this guide for the battery. While you check/change your battery take a look at the charging connector soldered to the logic board. You may have to resolder it or replace it.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
I don't think its a battery issue due to his loose charger fits now.... Can I use USB port?
さんによる
No it is not made for that charging
さんによる
コメントを追加
回答を追加する
lunakrazyshedevil71 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 301
