メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Camera no longer works after display exchange.
Hello,
I have changed the display on my iPhone. 6 After starting the iPhone, the front AND back camera stop working.
I have a hard reset performed, and have my iPhone reset to factory settings.
Now i have baught and installed a new front and back camera, but it still doesn't work.
Someone has a solution?
sorry for my bad english :D
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
最も参考になった回答
Hi Manuel, there is a small IC called U2301 on iphone 6 motherboard that is responsible for giving the tension that allows both cameras to work. Is near the camera connector and covered with black glue but I'm linking a picture to show you where. You should check if you could have damaged it while removing the lcd, digitizer and camera connector on the board. Bye.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
i also had the same issue and the motherboard component wat at fault which i got replace, brought he new from here at ifixit and its working like a butter now
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
@lissacoffey which component did you replace?
さんによる
コメントを追加
Hi Manuel
Can you check if there is any damage on the connectors on the motherboard, or perhaps component on the motherboard is broken?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Which component could it be?
さんによる
I am not sure which component can be (I am not as good as some people around here), but if something is missing from the board this mean something is wrong :)
さんによる
コメントを追加
回答を追加する
Manuel MajorFox さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 112
