Water or coffee is dispensing slowly
The water or coffee is not following freely. It is pouring slowly into the cup.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
if the water or coffee are pouring slowly then the top needle may not be sufficiently penetrating the K-Cup. Beside that, you need to clean or sharpen the needle.
If the needle is fine, then you need to check on the hose. It maybe partially clogged.
このアンサーは役に立ちましたか?
I also have this problem but all the water and air tubes/passages are clear of obstructions, there are no kinks in any of the tubing and the air pump works fine.
The coffee brews but the water discharge into the cup is very slow and weak compared to when the K10 was new
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 1,984
