メインコンテンツにスキップ
モデル番号A1288/ 8, 16もしくは32 GB容量
451回答 すべてを表示
締切られた回答
HELP! Touch screen not responding after water damage.
After leaving my water bottle in my bag, my iPod got wet. Stupid of me, but I left it on and tried to check if the music still worked. After awhile, I tried to turn it off, but the touch screen wouldn't work. So I left it in a bowl of rice for a couple of days and found that the iPod turned on and everything was great until I tried to unlock my iPod. I again put it in rice (thinking that the water that had not been absorbed by the water would be absorbed), and the touch screen is still not working!! I then tried restoring it, which was just a pain in the butt and my iPod won't restart for some reason >.<.
Any pointer/suggestions? Should I put it in rice again? Or should I just fork up the money to get it repaired by Apple or any other company??
Please and thank you!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
yo mommas so fatttttttt
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
and "yo momma" did not teach you any manners
さんによる
コメントを追加
You should try replacing the front panel / digitizer assembly (which contains the touch sensor).
iPod touch (Gen 2) Front Panel Assemblyの画像
製品
$29.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I've replaced the front/panel digitizer assembly however, i'm stuck with same issue. Touch screen is still not working. I've done almost everything i can...I'm starting to think i'm "SOL" or is there anything else i should try....please help
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 7,104
