メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
Advice before buying the lightning connector/reballing
Hey guys, I know this has been asked a lot of the times before but I really wanted a second opinion.
I bought a used iPhone 5 which has no sound during a call. Now, I've tested all 3 microphones (front and back camera + voice memo + Siri + VoIP) and the earpiece (voice memo + VoIP) and the proximity sensor (voice memo) and they all seem to work perfectly.
The other answers suggested that the lightning connector be replaced, although another suggested reballing a certain IC. Which one do you guys think would be the solution for me, given that all the hardware seems to work just fine.
Thanks a lot!
Ramneek
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
4 件のコメント
Can you give some clarification of the problem as I don't quite understand. You say there's no sound during a call, what do you mean by this? That the person on the other end of the call can't be heard? Is that just through the ear piece, or over loud speaker too?
You say that you have tested 3 X microphones and the ear piece - how have you done this? You confirm that the ear piece works, but that during a call, it doesn't work? How else have you tested it?
さんによる
So during a call, there is no audio whatsoever. The person I am calling doesn't hear me and I don't hear them, with and without loudspeaker.
The recorded a voice memo and played it through the earpiece so I know the bottom mic and the earpiece work. I also made videos through the front and back cameras, so I know the top front and back mics also work. Calling through a VoIP app like Viber works too.
The loudspeaker works because I can hear music through it.
Only during a call, there is no sound whatsoever. Another thing to note is that during a call, the iPhone becomes really really slow.
What do you think?
さんによる
What iOS are you on?
さんによる
The latest one - 9.2.1
さんによる
コメントを追加
2件の回答
最も参考になった回答
I've had a similar issue that was fixed by a hard reset and/or a factory reset. If all the mics work, it is unlikely that it is a hardware problem.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I've already restored the device using iTunes but the problem hasn't gone away. Does that mean it's a problem with the logic board?
Thanks so much for your reply btw!
さんによる
コメントを追加
I'm thinking that there are a few more things you can try. In settings, general, accessibility - turn off your "noise cancelling" then try a call and see if that makes any difference
Check also that holes for all 3 mics, front and back top, and then the bottom are all clear of dust / debris
If all of that makes no difference, you may have a problem with the sound control IC
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ramneek さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 100
