メインコンテンツにスキップ
2015年9月9日に発表されたiPad Mini 4では、iPad Air 2の性能を維持しつつ、フォームファクターが小型化されています。
176回答 すべてを表示
Will replacement glass and digitizer work on the Ipad Mini 4?
My son broke his Ipad mini pretty badly. I have the heat gun to remove the glass. I want to order new glass. But the ipad 4 is way more expensive than the other 1,2,3 models. What model and digitizer can I use?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
最も参考になった回答
The reason the iPad mini 4 is more expensive is because the digitizer/touch screen are glued to the LCD, so you have to replace both, making for expensive repair. Doing a glass only repair on the iPad mini 4 would be near impossible without the expensive and high tech tools. The iPad mini 1,2,3 the digitizer and LCD are not glued together so if the screen is broken you can just replace the digitizer/glass.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Hi. there, I have an Ipad Mini 2 the Screen is cracked. do I have to replace the LCD and Digitizer ? can you please explain why. Thank you!
さんによる
Just the glass only in the iPad mini 1/2/3 much cheaper repair.
The 4 has a glue between the entire lcd and touch digitizer so you cannot split it apart like the 1/2/3 models.
さんによる
コメントを追加
From what i understand
you want to use another glass/ digitiser from iPad mini 1,2or 3 on and iPad mini 4
if this is correct you can not use any other glass/ digitiser on iPad 4 other than what was intended sadly
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
also if you don't mind me asking how much is a new digitiser
さんによる
New digitizer is around $220
さんによる
now i know this is more expensive but you get a new iPad?
https://www.apple.com/support/ipad/repai...
さんによる
I don't think the ipad you get is new; I believe it is refurbished with a 90-day warranty. However, it may indeed be the best option.
さんによる
コメントを追加
Hi I had tried to separate the glass and the LCD and and punctured it. Now not working. Can i buy a new LCD to replace? How much is it? Will I need to keep any part from my old LCD for use. This is a mini apple ipad 4
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jenny Minerva さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 9,977
