メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Wont turn on after lcd replacement
I have changed the lcd and now it won't turn on. the issue is now that it won't turn on again. when connected to iTunes it is recognized as "the phone you are trying to activate needs a sim card to activate. or this item does not exist. When connected to charging cable it vibrates to times with 5 sec. interval.
the repair is not new to me, i have done this repair many times.
i have tried to mount an other lcd with the same result. I can read, that some threats describe the it could be issues with CPU. Does any of you have experience with this issue?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
The constant vibrate is the phone telling you it can not see a display. Look for a damaged digitizer connector or screw damage down the flex cable retaining bracket screw holes.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
I know I say this a lot, but have you tried a force restart?
iPhone 5を強制リセットする方法
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
But that reset does resolve a lot of issues with the iPhone
さんによる
Yes. I have tried hard reset several times. And I have tried to boot in dnu mode
さんによる
Hmm. Sounds like the phone is on and active. It's starting to sound like there's an issue with the sockets on your logic board. You sure your old LCD doesn't work? So we can rule out our new LCD being the issue?
さんによる
コメントを追加
Hi Imedic
thanks a lot for your replies. i have also tried with more than one lcd on this phone. i have also tried to change the charge port and jack component. do not know what next step to take, all ideas are welcome.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Carsten さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 89
