メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
782回答 すべてを表示
Pulled Out A Particular Wire
I pulled out a particular wire while installing my disk caddy for my new hard drive. Want to know whether it is vital to operations or not.
Currently Macpro is running normally, and I don't really have the equipment to solder it at home so I want to know whether it's worth getting someone to solder it for me/to obtain a solder for.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
3件の回答
ベストアンサー
no it's not the fan cable. You can see part of the fan cable at the upper right of the pict. I think that your broken cable is for the isight camera or bluethoot or wifi not sure...try these functions.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
It's definitely not wifi because that works. I don't really use the other two functions so it's alright for me. Thanks!
さんによる
コメントを追加
最も参考になった回答
Well that appears to be the wire to the fan. Stick it back in.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
Well I would except I'll need to solder it back in. Thanks for the answer though!
さんによる
It isn't soldered in the first place, why do it now, Just stop yanking on it.
さんによる
Well it used to be attached to something reattachable so it didn't need to be soldered. And yeah. I stopped yanking on it.
さんによる
コメントを追加
Lemerise is right. That is your isight camera cable and unfortunately there is no fix for that, I repair on component level with a stereo microscope and it is nearly impossible to fix! Your only option is to pull the glass and replace the cable or buy a used display and selling the old for parts if you wanted. That's it! See within the wire there are 10 strands that are microscopic if 1 of them is not together with the rest it will not work so your working on 2 wires the outer and the inner with 10 and there is four wires total.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Well I don't use the camera anyways so it's fine. But thanks for the advice.
さんによる
コメントを追加
回答を追加する
Xyilver さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 161
