broken hinge, white screen, How do I get my info off?
Broken L side hinge, screen turned white, haven't synced to my timecapsule in a while. How do I get my info off?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Assuming that your display is the only problem, you should be able to connect your computer to an external display so you can see what you're doing, and then back it up normally.
このアンサーは役に立ちましたか?
Both get +.
Plug your time capsule in and boot the machine. Time machine should automatically back it up even if you can't see the screen. Give it a couple of hours to make sure it's completed. Now plug the capsule into another Mac and restore your data via Time Machine. This can also be done from a system installation disk.
このアンサーは役に立ちましたか?
+ for the experience working with the hardware to know that
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,747
