メインコンテンツにスキップ
The Fujifilm X100T is the third-generation camera of the X100 series released in late 2014 by Fujifilm Corporation. It comes in two colors: black and silver, and can be identified with a capital T on the front. It is Wi-Fi capable and can take 16 megapixel photos.
5回答 すべてを表示
締切られた回答
What can I do if my camera got wet?
I accidentally spilled a water pitcher on my camera. It won't turn on and I am worried I cannot fix it. Is there any way to revive my camera? I do not want to buy new parts unless I have to.
Thank you!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Immediately turn off the camera after spilling water on it and take the battery out using our Battery Replacement Guide. This will allow the camera to fully dry and to avoid any possible damage that water can cause to the camera parts. Allow the camera dry for 1 - 2 days before putting the battery back in and turning the camera on.
If the camera still does not work, the motherboard might be damaged. Consider replacing the motherboard using our [|Motherboard Replacement Guide]
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 4
今までの合計 3,067
