Why won't my camera work when it is turned on?
When I switch the on/off button to "on", my camera won't turn on.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If the camera does not work when it is turned on, check to see if the battery is charged. Plug in the Camera and allow the battery to charge for a few minutes, then try to turn the device on.
If the camera still does not turn on, this could be a sign that you have a malfunctioning battery. If you have a malfunctioning battery, you can replace it using the Battery Replacement Guide for the device.
Source: Fujifilm X100T Troubleshooting
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 260
