Cant make calls, saying my lg is on airplane mode
My lg 4 g with metro won't let me call out, saying airplane modes on but its off
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
This link may be of relevance to your problem.
http://forum.xda-developers.com/sprint-g...
You may also wish to try a hard reset of your phone to see if this resolves your problem.
Be aware that a hard reset will erase all your downloaded apps and user data and restore your phone to a factory default condition. It will be like when you first bought it.
You may wish to backup your data first.
Before performing a hard reset ensure that the battery is charged. Do not perform a hard reset with the charger connected.
Here is a link that shows you how to do it.
http://www.hard-reset.com/lg-g4-hard-res...
Be patient, it takes a few minutes.
このアンサーは役に立ちましたか?
Try change the battery that help me
Just that
このアンサーは役に立ちましたか?
I just got my new battery, put it in, crossec my fingers, toes, legs and ❤, booted up and Volia! I'VE GOT PHONE PRIVILEGES
In case you don't read icons, that's a very big, and grateful, THANK YOU G4g4!! SMILES GOOD 4 DAYS ON END
My sons phone did the same thing. I cleared the cache then instead of message to turn off airplane mode it said it needed 911 installed. Somehow the 911 phone number got deleted so when I added it back in, the phone now works, doesn't give error messages and can make calls
このアンサーは役に立ちましたか?
For mine I had to reseat my sim card. I opened the case to see if it would do the same thing with no sim card. I pushed my sim card back a little and removed the sticker on top that was coming off. I expected it to say no sim card when I turned it on but to my surprise it said service. Finally, the problem was over. I dont know if it was pushing to sim card back or taking off the sticker (maybe it was snagging something) that worked. But between the two. It worked.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 6
過去 30 日: 51
今までの合計 34,473
