メインコンテンツにスキップ
The LG G4 was released in the US in early June 2015, as always focusing on high-end specifications and a refined fashion sense that makes it stand out in the premium smartphone market. Each version of the phone will have a different model number based on if it is sold by a carrier or unlocked (US or International). Some LG G4's are known to have bootloop problems.
73回答 すべてを表示
Cant make calls, saying my lg is on airplane mode
My lg 4 g with metro won't let me call out, saying airplane modes on but its off
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 9
コメントを追加
4件の回答
ベストアンサー
Hi,
This link may be of relevance to your problem.
http://forum.xda-developers.com/sprint-g...
You may also wish to try a hard reset of your phone to see if this resolves your problem.
Be aware that a hard reset will erase all your downloaded apps and user data and restore your phone to a factory default condition. It will be like when you first bought it.
You may wish to backup your data first.
Before performing a hard reset ensure that the battery is charged. Do not perform a hard reset with the charger connected.
Here is a link that shows you how to do it.
http://www.hard-reset.com/lg-g4-hard-res...
Be patient, it takes a few minutes.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Try change the battery that help me
Just that
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I just got my new battery, put it in, crossec my fingers, toes, legs and ❤, booted up and Volia! I'VE GOT PHONE PRIVILEGES
さんによる
In case you don't read icons, that's a very big, and grateful, THANK YOU G4g4!! SMILES GOOD 4 DAYS ON END
さんによる
コメントを追加
My sons phone did the same thing. I cleared the cache then instead of message to turn off airplane mode it said it needed 911 installed. Somehow the 911 phone number got deleted so when I added it back in, the phone now works, doesn't give error messages and can make calls
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
For mine I had to reseat my sim card. I opened the case to see if it would do the same thing with no sim card. I pushed my sim card back a little and removed the sticker on top that was coming off. I expected it to say no sim card when I turned it on but to my surprise it said service. Finally, the problem was over. I dont know if it was pushing to sim card back or taking off the sticker (maybe it was snagging something) that worked. But between the two. It worked.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
thomassechler さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 19
過去 30 日: 63
今までの合計 34,668
