メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Wi-Fi is grayed and No Bluetooth
My phone6 wifi connection is greyed out and blue tooth is not working, I have tried all the method post to web, the problem still not Fixed. look like have need replacement of the iPhone 6 Wi-Fi Antenna replacement.
Can someone tell me is
iPhone 6 Top Left Antenna
had fix the problem using above wifi replacement or any issue.
iPhone 6 Top Left Antennaの画像
製品
$9.99
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
The wifi antennae is the first thing I would look into, after that it's like what jump1n said, you'll have to have the board worked on
There isn't a guide for it, now. You're not supposed to use the teardowns as guides. But I do it all the time
iPhone 6 の分解
製品
$9.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had the same problem and with the iPhone 6 this is a very unknown issue and I researched into it and found this. Something may of come loose connector wise check thembut in setting under wifi address it says NA then yes try those but I reckon it's the wifi chip has benn moved from its place on the motherboard, replace that and it'll be good as new,
Hope I helped
Regards
Lucas
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
hklha さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 5
今までの合計 555
