メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone 6 will not charge.
Hey Guys,
Just had a quick question regarding charging on an Iphone 6. A customer brought in an Iphone 6 that would not charge, we tried a few different charging ports and the device would still not charge. When powered off, charging cable can be plugged into the phone and will boot. When plugged in the device displays a message saying please use apple charger, but the charger we were using is a Apple charger. She was using an off brand charger at one point. Anybody have any experience with this issue? Thank you in advance!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
"She was using an off brand charger"
There's your issue right there.
She has damaged the U2 IC chip, the message asking you to use a genuine charger (even if you are) is one symptom of it, more severe symptoms are:
- Overheating
- Fast battery drain (even in airplane mode)
- Fake charging (shows charging symbol, but percentage usually goes down)
- Phone charges when on, but if left to die, will not charge, but is able to come back on with a charged battery
The only fix for this is to replace the U2 IC chip.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
I figured it would be something on the board, we have tried everything else, thank you for the answer! I appreciate it.
さんによる
コメントを追加
Have you tried another battery? I have seen iPhone 6 batteries dying at a quicker rate than any other iPhone model.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I did try a different battery, it was able to boot up, but it still would not charge. :( Thank you for the suggestion!
さんによる
You've already replace the charge port, so that's the only other troubleshooting step I know. Im hoping nothing on the board is bad. I have seen off brand chargers cause problems. I've seen them destroy phones, although I have seen people use them without any issues as well. Can you try a different cable and power brick just to test? Im grasping at straws at this point.
さんによる
コメントを追加
Hi,you can take a moment to read this article How To Fix Slow Or Unable To Charge Problems May it can help you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
leevancleef さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 5,400
