Where can I find a replacement Lid for Starbucks Barista Aroma Grande
I need to replace my lid to the Starbucks Barista Aroma Grande Coffee Maker. Where do I go?
Wolfgang puck now carries the exact coffee maker! I just ordered a replacement lid today. They charged under $10 and I will have it in a week. Still love my Barista aroma grande. The model number is wptpcM010
このアンサーは役に立ちましたか?
It looks like they no longer carry it.
Unless you can determine who the actual manufacturer of the machine is you'll probably need to contact Starbucks. If they don't have any spare parts available I'd look for a broken machine on ebay or craigslist that has the part you need, and then you'll have some extra spare parts as well.
このアンサーは役に立ちましたか?
Here is what I found on another site. I have called and ordered. They indicated it is on back order, but it does appear to work.
The exact same lid is on the Wolfgang Puck WPTPCM010 coffee maker. (It's exactly like the Starbucks one - same size & fit.) Call (800) 275-8273 and order part # WPTPCM010-6; the product description is "LID FOR CARAFE". It will cost you $4.99 + 5.00 shipping. My Starbucks coffee pot works PERFECTLY again. Just make sure that you put the lid on the carafe correctly before you use it, since the seal is new.
このアンサーは役に立ちましたか?
Unfortunately, they stopped carrying it two years ago.
According to Phillips Saeco, they never m
anufactured any of the Starbucks drip coffee makers.
このアンサーは役に立ちましたか?
I called Wolfgang Puck _ No luck! Called Starbucks - no luck. Is there anyone out their who knows where
I can find the lid for a Starbucks Barista Aroma Grande 12 Cup?
このアンサーは役に立ちましたか?
I am in search of the same part. Ridiculous Starbucks doesn't offer a solution when the lid is necessary to make the entire pot function.
このアンサーは役に立ちましたか?
I have one of these coffee makers and the lid was giving me problems -- the washer on the underside of the lid went missing, which means the stem/stopper part of the lid is not held in place. The top of the lid (stopper part) and spring work okay. I took a small piece of stainless steel wire and wrapped it around the bottom of the stem so that it would no longer fall out.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 16
今までの合計 10,785
