メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone 6 locked after screen replacement
iPhone 6 locked after screen replacement. Message appears to connect to iTunes. When connecting to iTunes message on iTunes appears to unlock the iPhone with code. An endless loop.
Maybe an Apple lock when detecting an unoriginal screen? Don't know.
Please help. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 8
1件のコメント
is this still the case with changing the 6 screen?
i am just about to change one for a friend?
さんによる
コメントを追加
6件の回答
最も参考になった回答
Do the following ONLY IF ALL the following conditions are met:
You are sure that the device does not have Find my iPhone enabled, or you or the owner knows the Apple ID and password.
You have the original Touch ID subsystem (Home button assembly) on the phone and intact.
You are sure that the device was backed up to iCloud or iTunes before, or you don't care about the content on the phone.
Then,
Plug in the cable, turn off the device, press power + home button for 8 seconds, then release the power button but hold the home button until the device is recognised by iTunes.
このアンサーは役に立ちましたか?
スコア 11
12 件のコメント:
Tom, thanks. Worked out just perfect :-)
さんによる
atta boy Tom. you for real my dog.
さんによる
Amazing thanks... copied it to the letter and worked perfectly thank you
さんによる
I keep getting an 0xE8000015 unknown error everytime the phone connects to itunes. When I hold the buttons i only get the apple logo and then it blinks. help i dont want to have to spend another 150 to send it back to apple
さんによる
not all heroes wear capes but you need one!
さんによる
7件以上のコメントを表示
コメントを追加
Hello,
I'm not sure how this could happen to you. Best it to restore iPhone via iTunes. Basicliy if you cant enter passcode somehow, enter it! If u cant, restore it or put new iOS via DFU or Recovery mode.
Hope it helps, Nikola
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Hi Nikola,
thank you for your answer. I can't enter passcode on the phone. The only screen is the emergency call, and a message "connect to iTunes". Then when I connect to iTunes I get the message "Enter passcode on iPhone to unlock". Not able to get into to the restore menu.
What is DFU?
さんによる
Why u cant enter passcode? ur touch doesnt work?
DFU mode is Device Firmware Update, its used in case u cant boot properly device or if u need downgrade iOS
さんによる
The phone is already disabled by too many failed passcode attempts at this point, recovery or DFU is the only way out.
さんによる
コメントを追加
iphone passcode unlock. You can remove the passcode by restoring your device from iTunes or Find My iPhone if you've turned it on before. The catch here is that you will lose your data by following the above method, so you should be aware of that.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I did tried and it's work well
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have unlocked iPhone 6s plus after getting it from USA to India, one day screen was broken ,so I replaced it OEM brand display, after a day my phone got locked and it is asking activation is required, Any help can be appreciated
さんによる
コメントを追加
I keep getting error (9) what dose that mean when it's restoring
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem before and the Joyoshare iPasscode Unlocker fix it, so maybe you can have a try, it’s helpful and safe.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
larsthue さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 12
今までの合計 30,119
