They wont turn on at all not even leds
My beats studio wireless wont turn on at all not even the leds turn on I put them to charge nothing turn on I try to reset nothing happens leds don't blink they don't turn on . are they jus dead now ?
Hi,
Have you tried charging them via a USB cable connected to a working PC? If that works then your charger may be faulty.
If that doesn't work, then have you tried a different USB cable between your charger and headphones or PC and headphones?
If that works then your charging cable is faulty.
If neither option works then the charging circuit or the battery in your headphones is faulty and needs to be replaced.
Check the warranty period on your headphones and if still valid contact Apple regarding a warranty service.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 253
