メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
Battery percent does not increase
When I charge my Iphone 6S, the battery is charged but it does not show in the display.
If I shut the phone off and then restart it the percentage "jumps" to the right level.
How do I fix that (I have the latest IOS)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Battery recall program:
https://www.apple.com/support/iphone6s-u...
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
最も参考になった回答
There seem to be a lot of different opinions on how to solve this issue, some easier to try out than other.
First of all, go into settings and turn off "show battery in percentage", then reboot the phone, recharge it and turn on "show battery in percentage".
Some say you need to calibrate the battery. This is done by fully discharging the phone, to the point where it turns off by itself. Then charge the phone to 100% and then discharging the phone again, without tuning the phone off for the entire period. However, I am not sure about the effectiveness of this method, but it is easy to try.
You could try and restore the phone to factory settings, to see if this elleviates the issue.
Now onto hardware issues.
If none of the above fixes solves the issue, you need to replace the battery. As you have the phone open, you can check for missing components around the battery connector - epscially the FL11 shown here:
Last resort would be to change the dock/charging connector.
Hopefully one of the points above will help you solve the problem.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Nils Edlund さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 1,498
