What if my clutch pedal switch is bad
2001 Nissan Xterra. what if the clutch pedal switch is bad
Usually the only function of a clutch pedal switch is to make sure you have a foot on the clutch when starting the engine.
There are potentially 2 failure modes:
1 you can't engage the starter even if you do step on the clutch pedal
2 you no longer have to step on the clutch to engage the starter
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 253
Ashley Woody clutch pedal switch? Not sure what you are referring to. What does or does your clutch not do? Give us a better idea of what your question is about.
oldturkey03 さんによる
