メインコンテンツにスキップ
モデル番号A1502 / 2.4, 2.6, 2.8 GHz デュアルコアIntelプロセッサ/ 2013年10月発売
552回答 すべてを表示
Cannot determine that fan is running, help?
I believe my fan has died. Tried some fan control utilities to bump up fan speed so I could "hear" it, but I still can't determine that it's running. Seems to overheat mildly even with non-intensive use, and at no point can I distinctly hear or feel any indication of an operable fan. Anyone have any ideas for how I might determine if it's working?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント
You do know that macbook retina fan does not run constant like the other non retina macbooks right? I worked on 2 before I saw this myself. Take the back cover loose , use the macbook until it gets hot turn it on it's side without closing the lid and check the fan.
さんによる
@John - All MBP's use variable speed fans and depending on the temp the fan may not be running at all. The retina class systems are no different here.
さんによる
No you don't understand. I've worked on 4 of the retinas the fan DOES NOT Engage at startup if you haven't worked on one these before then you don't know what your talking about. All the other macbook pro unibody start immediatley the Retina models do not!
If you have one or working on one look for yourself.
さんによる
@John - re-read what you wrote: "You do know that macbook retina fan does not run constant like the other non retina MacBook's right?" You are inferring running not startup. As to start up all that tells you the fan is powered not the state of SMC and the sensors.
さんによる
His questions are about not feeling the fan I'm giving him insight , you can reword it how you want non MBP fan spin at chime, Retina Macbook NO startup at all and sometimes not for long time ,simple.
さんによる
コメントを追加
1 件の回答
ベストアンサー
I would recommend you use this App: TG Pro. It will allow you to see your fan's RPM as well as what the thermal sensors see graphically. Make sure you remove anything you currently have running before you install this as you don't want it conflicting. Post a screenshot of the sensor & fan status for us to see in your question (edit mode)
As to your fan it maybe in need of cleaning. Dust builds up within the blades as well as the cooling fins in the heat sink. You'll need to open your system and carefully blowout the dust with a can of Can'ed Air and a soft brush to lightly scrub things down.
Do make sure you practice good ESD precautions! It's winter so the air is dry! Static electricity will kill your system.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
David Ward さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 3,034
