メインコンテンツにスキップ
The Kenmore Elite HE3 is a washing machine by Kenmore.
669回答 すべてを表示
Help concerning Door Boot Seal
I have a Kenmore He3t Washer. The door boot seal has a small tear and I am getting some water leaking out of the unit during the wash cycle. I should also mention that my Kenmore dryer is stacked on top of the washer.
My question is, can the small tear in the existing boot seal somehow be repaired? If not, in order to install a new boot seal, do I have to remove the dryer from the top of the unit or can a new boot seal be installed by accessing only the front the washer?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
Please give us your model number so the part can be looked up.
さんによる
The model number is 110 44832 202
さんによる
Thank you very much. One last question,. Although the video says you need to remove the top panel of the washer, I didn't really understand why. It looks to me like you can get access to everything you need just by removing the front panel. That way I don't need to worry about removing the dryer from the top of the washer. Am I missing something?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Door Boot Seal
RepairClinic Item # 1027300
Door Boot Seal - Part # 1027300 Mfg Part # 8182119
Watch Video:
Skill Level: Skill Level
This part fits your Washing Machine
Washing machine door boot. If the washer is leaking, the door boot may have a tear in it. Overloading the washer is the most common cause for a torn door boot.
OEM Part - Manufacturer #8182119
Related Items:
Boot Seal Retaining Ring #1059565
Boot Seal Retaining Ring #1059566
Cleaner #1373065
http://www.repairclinic.com/Shop-For-Par...
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
John さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 40
今までの合計 3,207
