メインコンテンツにスキップ
人気のGalaxy製品ラインを含むSamsungのAndroidベースの携帯電話の修理ガイドと分解情報です。
13156回答 すべてを表示
Why is the screen clicking itself?
Bottom of my screen stops working most of the time that most buttons that appear around the area become inactive - i have to rotate the screen to landscape just to use these buttons. Occasionally the screen would also start to click things randomly without any touch from me. I'm confused and not really sure if it's software or hardware related, i tried hard reset but it didn't help. The rest of the screen is fine and I've done the screen test which shows the problem is only at the bottom.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
2件の回答
最も参考になった回答
It sounds like you've got a lingering issue with the Digitizer (touch panel) on your device.
Given that both issues: 1) The dead spot at the bottom of the screen, and 2) the 'ghost touches' you're experiencing, are Digitizer related, replacing your screen should do the trick.
Unfortunately, Samsung devices tend to have the LCD/Digitizer and Glass all fused together, making a screen repair more costly and/or difficult.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Samsung phones are usually easier to separate the LCD and digitizer...
さんによる
I meant 'easier' as in other devices without fused displays and separate glass/digitizer layer being much easier than Samsung Glass-only, especially if he's not a technician.
さんによる
The phone works just fine most of the time but the problem can be a pain so I'm contemplating taking it to a pro for the screen change. Thanks for the info will update soon as I get it fixed.
さんによる
コメントを追加
I actually have a problem with my phone. My phone will click on things non stop, but it's only in one part of the screen. I can't go less than 5 minutes without it having a spazz attack. Also, this started happening as soon as I got this phone. Another thing is, if I'm holding my phone too tight or something, it'll start clicking on things as well. It's really frustrating and hard to deal with. Sometimes I'll turn my phone off, turn it back on, enter my pin, and it will stop for a few minutes but then it will continue doing it again. Can someone please help me?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I got m32 for my father and this issue occurred very first day. It didn't occur again until few days but now it is more frequent!
This phone starts clicks on it's own and don't allow
to intervene. We recorded it using another phone and below is the link.
Please suggest a fix for it.
https://youtu.be/0Ms34-PlZgI
さんによる
コメントを追加
回答を追加する
Gilbert Alando さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 23
今までの合計 13,059
