bleached out video audio ok
video is bleached out(white No contrast).tried unit on another tv same problem.audio is fine and some colors are ok.like the brightness control on tv is turned all the way up.turning it down has no effect on problem.
1. Have you tried a different A/V cable? Is yours damaged in any way?
2. Is the connector on the board nice and secure (it may have worked itself loose after all these years.)
3. If 1 & 2 don't work you might have a failure in the logic board (specifically the graphics section).
Hope this helps.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,317
