How can I delete my text messages
I have two Sims and I try to delete messages and they won't delete
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hello tina rose,
Note: steps and options may depend on the currant Android version of your phone
Cheers!
このアンサーは役に立ちましたか?
Hi,
Which cell phone do you have? As different sets are having different process on same thing. Still you will try one thing i will suggest you-
just go to the message box and select the message you want to delete. May be when you touch the screen for select the message you want to delete, it shows a option "Delete Thread" or "delete". If it is then click on this option. Your message will be deleted. Otherwise please specify first, which cell phone you are using...
このアンサーは役に立ちましたか?
i am using blu energy x plus with straighttalk and that didn't work but thanks
I am using Tecno Spark. Pressing the delete option after highlighting the message, doesn't work. All other options that indicates "delete message" cannot delete the message (s).
I'm using a techno spark.....can't deleate messages
Simple really on the Doro … go to settings, select the delete option and it comes up with options to delete all inbox, outbox, sent and finally all messages. Choose which and press ok.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 6
過去 30 日: 18
今までの合計 8,285
