メインコンテンツにスキップ
The BLU Energy X Plus has a 5.5 ' HD display, 1GB ram, and an 8mp camera.
42回答 すべてを表示
How can I delete my text messages
I have two Sims and I try to delete messages and they won't delete
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
Hello tina rose,
  • Open SMS on your phone and press option button (left side of home button)
  • Select "Settings"
  • Find "Manage SIM card messages "
  • for delete one massage > long press on relevant SMS and select Delete"
  • to delete all "press option button and select "delete option"
Note: steps and options may depend on the currant Android version of your phone
Cheers!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi,
Which cell phone do you have? As different sets are having different process on same thing. Still you will try one thing i will suggest you-
just go to the message box and select the message you want to delete. May be when you touch the screen for select the message you want to delete, it shows a option "Delete Thread" or "delete". If it is then click on this option. Your message will be deleted. Otherwise please specify first, which cell phone you are using...
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
i am using blu energy x plus with straighttalk and that didn't work but thanks
さんによる
I am using Tecno Spark. Pressing the delete option after highlighting the message, doesn't work. All other options that indicates "delete message" cannot delete the message (s).
さんによる
I'm using a techno spark.....can't deleate messages
さんによる
コメントを追加
Simple really on the Doro … go to settings, select the delete option and it comes up with options to delete all inbox, outbox, sent and finally all messages. Choose which and press ok.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tina rose さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 18
今までの合計 8,284
