メインコンテンツにスキップ
The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
Why wont computer turn on even though charging light is on?
My computer will not turn on. The charging light is on when its plugged in and the "on" light will flash once when you hit the power button, but it never comes on or acts like its going too. Any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
Try another charger.
さんによる
Do you have a multi meter If so get a reading on the battery and see if its actually getting a charge and test the power unit it may be defective and only supplying enough power to light the lights
さんによる
コメントを追加
7件の回答
最も参考になった回答
disconnect the power cord, remove battery, hold power button down for about 30 seconds, reassemble everything, press power button report back with results
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I have the same problem. Acer C720P does not turn on. Tried the suggestions in this thread with no luck. The blue light on the right side stays on only if charger is plugged in. The light on the left side is not on at all. Trying a different charger and battery did not work. When I followed the instructions of Joshua Fiu (below), the light on the right was blinking red. I also tried taping the small switch down (located inside next to the right hinge), as indicated in another thread and it has not made a difference either. Maybe needs a motherboard?
さんによる
This helped! Thank you so much! Unplugged, held power button for 30 sec., plugged in, hit power button and tada, finally working again! Thank you, thank you, thank you!
さんによる
コメントを追加
When the blue light flashes once but doesn't stay on, this is almost always a bad motherboard aka "Main Board". Source: I have repaired 100's of c720p in our school district.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Tim, we have had several c720 mainboards go out for us as well, so I'm curious. Did you repair the mainboards, or just replace them? If you did repair them, what component did you repair on the mainboard that fixed the issue? Thanks!
さんによる
We have the exact same problem with several units. Is there a repair for the mainboard or just replace it?
さんによる
コメントを追加
Hi I’m having trouble with my chrome book to.It won’t turn on but the charger is working but the computer is blinking red for no reason
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Did what you said, plus left the battery out for a few hours. Put it back in and got the same issue. When I push the power button, the blue light will come on for a second or so, then go out. Nothing on the screen and no sound from the computer, fan, etc.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Remove your charger from your Laptop
Remove the battery as well
Press the power button for 1 minute to drain whatever power is left in your laptop
Note
After following the 3 steps
Do not plug the battery in, just press the power button while the charger is connected to the laptop.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Have tried all of these and no go. The only thing is that it pops up with the opening screen that says Google chromebook but no luck getting past it. Any ideas?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Screen does not turn on. Power light is on and all lights are blue. Unable to turn off by pressing button.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Steve Cameron さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 5,438
