メインコンテンツにスキップ
モデル番号はA1059もしくはA1099/20、40、60GBハードドライブ/タッチ反応クリックホイール
227回答 すべてを表示
Swollen battery affecting middle button.
Old first generation iPod "brick" required new battery 4 years ago that was swollen and preventing middle button from functioning. Apple retailer did repairs but now Apple is prohibiting their stores from working on discontinued products or even ordering parts. This is a relic that still works great. Appreciate any suggestions or options vs. purchasing a replacement.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Joe, lets identify your iPod properly first. The first generation iPod did not exist as a 60Gb model. What is the AXXXX number of your iPod? What repairs were done and what are the issues now?
さんによる
Model No. A1099, EMC No. 2022. Circa 2004. Sorry, may have been ill advised regarding what generation it is.
4 years ago the center button became stiff and unresponsive. Turned out the battery was going bad and characteristically swells in the center right under the center button. The ring and other controls were not affected. Local Apple reseller tech easily repaired it. Same problem has now reoccurred, and the same Apple tech that fixed it last time feels it's the same issue. But, Apple now prohibits him from working the device.
さんによる
コメントを追加
2件の回答
ベストアンサー
Joe, first thing you want to do is to open it up. Use this guide for that. Discard the battery properly and of course replace with a new one. At this time I would consider replacing the click wheel. A replacement may be a bit hard to find, but they are still around. Follow this guide for that and as a last step remove the clickwheel. It is simply glued in to the front panel
iPod 4th Generation or Photo バッテリーの画像
ガイド
iPod 第4世代またはPhotoのバッテリーの交換
難易度:
中レベル
15 minutes - 1 hour
iPod 4th Generation or Photo ロジックボードの画像
ガイド
iPod 第4世代またはPhotoのロジックボードの交換
難易度:
中レベル
20 - 45 minutes
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I'm guessing you have an iPod Video 60GB. You can get the part from iFixIt:
iPod Video 60/80 GB Battery
Here's the repair guide (make sure your iPod is the same as this before ordering the battery):
iPod 第5世代(ビデオ) バッテリーの交換
iPod Video 60/80 GB Batteryの画像
製品
$13.99
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
回答を追加する
Joe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 295
