Does anybody know what this component is?
Hello,
I have a component that is broken from the logic board of a Macbook air A1466. Can anybody tell me what that component is and is there a replacement component for?
この質問は役に立ちましたか?
Hello,
この質問は役に立ちましたか?
yordimeijers that is reference designator C7372 which is a 62UF 11V 20% Tant(alum)-Poly(mer) capacitor in a Case B2S-1 package. this particular model is a NeoCapacitor made by NEC/Tokin. Remember that with capacitors you can increase the capacitance as well as the voltage in case you have trouble matching it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 441
3 件のコメント
Thanks for your answer.
Its hard to find a 62uf capacitor, is a 68uf capacitor also good?
@xcesv4c At the end of the day i'm home, then i look for the 820xxxx number on the logic-board.
yordimeijers さんによる
Yes you can use a higher capacitor.
oldturkey03 さんによる
You will need to solder on a new one,. What is the 820-XXXX number listed on the motherboard? There are many different types of boards for these laptops
Matt M さんによる
