メインコンテンツにスキップ
Nintendoのハンドヘルドデバイスは2011年2月に発売されました。モデル番号はCTR-001です。
456回答 すべてを表示
締切られた回答
My R button on my 3DS is stuck down. How do I Fix it?
The button is stuck in the "pressed" position. To get my 3DS to respond as if it weren't being press, I have to pull the edge of the button up. When it goes back down, I do not hear the clicking sound the other 3 shoulder buttons make when they're pressed. The button is stuck down on the right, away from the center of the system. I've uploaded some images as well.
http://imgur.com/a/byG8P
The 1st and 3rd images are of my L button, which isn't broken. They're there for quick reference.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
There is a small spring that pushes the button out this may be broke or the pin that holds the spring may have slipped if your game to take the controller apart the spring is similar to what you would find in a retractable pen
Nintendo 3DSの右ショルダーボタンの交換
The guide can help you through the teardown
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
this spring will be a lot smaller just looked in a pen for reference and its definitely gonna be different
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 7,535
