メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
締切られた回答
does not charge, does not show connection to I tune.
I fix the broken screen of I6 and put back together. worked great. I realize it was not charging keep on saying cable is not compatible. I tried this
hold the dismiss and unplug the charger and put back in. It showed charging sign but actually didn't charge. I noticed charging percentage was going down.
I connected it to computer and tried to upgrade the software, then it stuck in I tune showed the problem of -18 and later on 2001.
I have soft ware downloaded to get exit from i tune ( i phone care for Mac) and I tried to exit but it say no connection to the computer while there was connection. I got new cable from at&t store compatible with apple. again it did not help.
How to solve this. I have same problem with I 4s too.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You might need a new charge port. Also try using a full original cable from the Apple Store.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I tried both , did not work.
さんによる
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 75
